I wrote a perl program that reads messages from a mail box and then subsequently change the status of some services in nagios.
I Use submit_check_result, but does not accept variables ($ ServerName $ ServiceName $ Status $ Messagges) but only direct values (Srv_15 Svc_tcp_2365 0 "Alert On"). Is there a way to pass variables to submit_check_result?
Thank you
submit_check_result
submit_check_result
Reason: marking with green check mark
Re: submit_check_result
If you're using the submit_check_result provided by Nagios Core, yes that should accept arguments. More info about the underlying command that this script uses:
https://old.nagios.org/developerinfo/ex ... and_id=114
How are you passing these variables to submit_check_result? If you could post the section of your Perl script that is responsible for that bit, it would be helpful.
Thanks mcapra,
Now in my program I write something like:
if ($EventStatus == 0){
system('/usr/local/nagios/libexec/eventhandlers/submit_check_result SRV_LNX1 MAIL 0 "Text describing the event"');
you can instead use the defined variables in Perl?
my EventStatus = (regex for find evet status ( ... ));
my hostname = (regex for find hostname ( ... ));
my servicename (regex for servicename ( ... ));
my alert = (regex for string describing the event( ... ));
if ($Status == 0){
system('/usr/local/nagios/libexec/eventhandlers/submit_check_result hostname servicename EventStatus alert);
if ($Status == 0){
Sure, I would just wrap them in quotes or use a Perl function to escape them for the CLI to be safe. That aside, something like this should work:
my $EventStatus = /*regex result goes here*/;
my $hostname = /*regex result goes here*/;
my $servicename = /*regex result goes here*/;
my $alert = /*regex result goes here*/;
if ($Status == 0) {
system("/usr/local/nagios/libexec/eventhandlers/submit_check_result '$EventStatus' '$hostname' '$servicename' '$alert'");
I'll do a test and I will update you
Thank you
Elvino
Thank you
Elvino
- Former Nagios Staff
Fantastic! Let us know how it goes!
thanks dwhitfield, everything works fine!!!!
Tarzan
Tarzan
Fantastic news! Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
Okay we close the thread.
Thank you and greetings
Tarzan
Tarzan
