add a warning check to a decemel place change
chrisbooth
https://support.nagios.com/forum/viewto ... 2&start=10
following on from this locked soloution, i'd like to know how to add a warning and critical check to this.
#!/bin/bash
hostaddress=$1
./check_snmp -H $hostaddress -C public -o .1.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1 | awk -F'|' '{split($1,array_left,"-");} {split($2,array_right,"=");} {print array_left[1]"- "array_left[2]/10"|"array_right[1]"="array_right[2]/10;}'
this script works but i'm not sure or how to add a warning and critical check to it
#!/bin/bash
hostaddress=$1
Re: add a warning check to a decemel place change
Can you shed a little more light on what you're trying to accomplish with this script? Sharing it's current output and describing the warning/critical criteria would be helpful.
Generally speaking, you should be able to do something like this in most languages:
if (warning criteria)
exit 1
else if (critical criteria)
exit 2
chrisbooth
but i'm wrapping a check within a check.
so i'm not sure where i should be putting the -w -c
The "correct" way to navigate this would be to revise your script to include proper analysis of the output of this command:
Intuitively, it might make sense to pass the warning/critical threshold to the check_snmp command. But the issue is that the awk you are piping the plugin's output into will strip out the exit code at a minimum, which is important for Nagios in determining the state of the check.
Can you share this script's output? We might be able to offer some advice on how to best tackle this if we had additional information regarding all the variables in play. It's hard to tell what the OID is spitting out and what the awk is doing to the result of check_snmp.
./check_snmp -H $hostaddress -C public -o .1.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1 | awk -F'|' '{split($1,array_left,"-");} {split($2,array_right,"=");} {print array_left[1]"- "array_left[2]/10"|"array_right[1]"="array_right[2]/10;}'Can you share this script's output? We might be able to offer some advice on how to best tackle this if we had additional information regarding all the variables in play. It's hard to tell what the OID is spitting out and what the awk is doing to the result of check_snmp.
chrisbooth
bash +x ./check_apc_pdu 10.101.24.95
SNMP OK - 9.1| iso.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1=9.1Code: Select all
bash +x ./check_apc_pdu 10.101.24.95 -w 6 -c 8
SNMP OK - 9.1| iso.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1=9.1-
chrisbooth
mcapra wrote:The "correct" way to navigate this would be to revise your script to include proper analysis of the output of this command:
Intuitively, it might make sense to pass the warning/critical threshold to the check_snmp command. But the issue is that the awk you are piping the plugin's output into will strip out the exit code at a minimum, which is important for Nagios in determining the state of the check.Code: Select all
here's the output of your above suggestion
./check_snmp -H 10.101.24.95 -C public -o .1.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1 | awk -F'|' '{split($1,array_left,"-");} {split($2,array_right,"=");} {print array_left[1]"- "array_left[2]/10"|"array_right[1]"="array_right[2]/10;}'
SNMP OK - 9| iso.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1=9Code: Select all
root@prodsysnagios(/usr/local/nagios/libexec):echo $?
0Re: add a warning check to a decemel place change
Is your intention to see if the output is 9 VS 9.1? Or is it more a question of "does a decimal point exist" ie, is the output 9 or 9.0?
chrisbooth
the above fixes the decemel place from being incorrect 90 to correct 9.
the issue now is i want a warning and critical thresholds to work
at the moment i dont know where i should put them in the above code to work.
it always replys with ok no matter where i put it at the moment
all i want to do is convert the apc output from 90 to 9 and then have threasholds to work.
if there's a better solution to this than the above i'd love to know
We don't typically offer advice specific to plugin development.
This is probably a typing issue within how check_snmp was written though if i'm understanding the problem correctly. It's not as simple as just parsing the plugin's output and then comparing the warning/critical thresholds after the fact; The warning/critical thresholds will come into play before any awk gets executed in this case:
So the gist of it is that you'd probably need to fork/alter check_snmp and bake the "change 90 to 9 or 91 to 9.1" part into the Perl.
