Configuration Wizards Success with no any info in op center
X.Liu
Post by X.Liu »
HI , i installed Nagios Xi 5.4 on Redhat 6.4 x86-64 ,ti successed . Then i add a monitor on a windows desktop with Configuration Wizards , and it successed with no any wrong tips . but when i return to the operator center to see the hosts detail and service detail ,there is no any records . i go through the "Nagios Support Knowledgebase" , i try to fix it with excute the following shell , accroding the article “ Nagios XI - Configuration Applies, No Changes Take Place" at
https://support.nagios.com/kb/article.p ... ategory=44
/usr/local/nagiosxi/scripts/reset_config_perms.sh
the picture is my configuration wizards step info
it doesn`t work ,so please give me some help , Thanks
Re: Configuration Wizards Success with no any info in op cen
Lets reset the daemons that nagios uses to run and see if that fixes the issue.
Login as root to the XI server and run the following
service nagios stop
service ndo2db stop
killall -9 nagios
service ndo2db start
service nagios start
Give the server a minute to run, login to the GUI and see if the hosts show up now.
If not, run the following commands and post the output.
su nagios
./reconfigure_nagios.sh
ps -ef --cols=300
