Hi All,
Have anotherquestion. We are currently running Nagios Core and looking into upgrading to NagiosXI. Another issue we've run into is that the NRPE installed for NagiosXI is different than what you get in the install agent provided by NagiosXI. Not all the same plugins are available and the more serious issue, it seems the plugin arguments entered by the NagiosXI wizards are not the same as what is used by the older NRPE installed when we built Nagios Core. Is there a guide or FAQ on upgrading from Core to XI, or which plugins have different arguments? I ran the wizard for a linux host and none of the plugins worked unless I manually adjusted the arguements entered by the wizard.
Any suggestions on where I can look to see what I can do about adapting Core to XI?
Nagios Core to NagiosXI.
Re: Nagios Core to NagiosXI.
I believe this is the only document we have on migrating from Nagios Core:
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
