Hello
Nagios 4.1 Core
NSCLIENT 1.4.3
Windows 2008 R2 Server 64 bit
I posted an early issue where this server had a few services not working and the person on here no names suggested I upgrade the NSCLIENT I did that and then nothing worked.
I uninstalled that version restarted the server deleted the entire folder of nsclient++
After reinstalling nsclient 1.4.3 now the folder does not contain all the files I had in there now.
So when I reinstalled for the third time I try to do this
[codeC:\Program Files\NSClient++>nscp settings --generate --add-defaults --load-all
e rvice\NSClient++.cpp:347 Failed to register plugin: Could not load library: 1
4001: The application has failed to start because its side-by-side configuration
is incorrect. Please see the application event log or use the command-line sxst
race.exe tool for more detail.
: C:\Program Files\NSClient++\\modules\DotnetPlugins.dll in file: DotnetPlugins
26: The specified module could not be found.
: C:\Program Files\NSClient++\\modules\PythonScript.dll in file: PythonScript
Adding default values][/code]
On my other servers I have this file python27.dll
What am I missing
on the Nagios gui I see this
Check All Service
Notifications for this service have been disabled
UNKNOWN 01-23-2017 21:04:00 0d 0h 14m 30s 3/3 Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
Check Disk Usage
UNKNOWN 01-23-2017 21:04:10 0d 0h 14m 20s 3/3 Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
Check OS Version
UNKNOWN 01-23-2017 21:04:02 0d 0h 14m 28s 3/3 Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
Windows Users
UNKNOWN 01-23-2017 21:03:59 0d 0h 14m 31s 3/3 Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
Whats missing
NRPE not working on One Server
- Former Nagios Staff
Re: NRPE not working on One Server
Is it possible you installed Python 3 instead of Python 2?
Also, could you clarify the version of NSClient you are running? I'm assuming it's 0.4.1.3 rather than 1.4.3 but maybe you mean 0.4.3?
I figured it out.
I had to modify the nsclient.ini file
Now all working.
Please lock this now as resolved
Now all working.
