arguments in commands
nagios_aws
Post by nagios_aws »
Hello everyone,
to follow up my first topic : https://support.nagios.com/forum/viewto ... =6&t=41911
It worked for one server, but not for another ...
when I try to launch the check from Nagios server, I got this :
/usr/local/nagios/libexec/check_nrpe -H WORKINGSERVER-c windows_flexlm -a "--port 22222"
DOWN
/usr/local/nagios/libexec/check_nrpe -H NOTWORKINGSERVER-c windows_flexlm -a "--port 22222"
The command (windows_flexlm) returned an invalid return code: 255
return code "DOWN" is normal right now.
I'm currently using 0.5.0.62 2016-09-14 agent on both servers, same nsclient.ini, same boot.ini, same Tools and plugins of my own, same Perl version, same command for both ...
I tried this :
/usr/local/nagios/libexec/check_nrpe -H NOTWORKINGSERVER-c windows_flexlm -a "22222"
DOWN
and it worked ...
here is the definition of command in both nsclient.ini :
windows_flexlm=perl check_flexlm.pl --port $ARG1$
and in Nagios Webportal :
$USER1$/check_nrpe -H $HOSTADDRESS$ -c windows_flexlm -a "--port $ARG1$"
Do you have any ideas on how to fix that ?
Please ask for more informations if needed
Thank you
Re: arguments in commands
Can you try manually executing the perl script on the Windows host and see what is returned? Please post the full result. Wondering if it'll come back with DOWN or the same thing you're seeing in Nagios.
nagios_aws
forgot to tell but I can run it without problems using the command :
perl check_flexlm.pl --port 22222
I think there is a problem in communication from Nagios Server and Nagios Agent ...
nagios_aws
I also used the "nscp test" in a command prompt, then launch my command, you can see the result in attachment (it works as expected)
nagios_aws
here is what I have now in nscp test command line:
windows_flexlm_daemon 27150
D ext-script Possible missing argument in: perl check_flexlm.pl --port 27150 --v
endor $ARG2$
D ext-script Command line: perl check_flexlm.pl --port 27150 --vendor $ARG2$
L cli CRITICAL: $ARG2$: DOWN
I have the config file in attachment, and this in "command" page in Nagios Portal :
windows_flexlm_daemon 	$USER1$/check_nrpe -H $HOSTADDRESS$ -c windows_flexlm -a "$ARG1$ $ARG2$"
The windows_flexlm_daemon command that is defined in the nsclient.ini file has 2 arguments but the command on the Nagios server is using the windows_flexlm command which only uses one argument.
Try changing the command on the Nagios server from
to
windows_flexlm_daemon    $USER1$/check_nrpe -H $HOSTADDRESS$ -c windows_flexlm_daemon -a "$ARG1$ $ARG2$"
Save the change and Apply the Config, see if that fixes the issue.
nagios_aws
I finally fixed this, here is the solution :
nsclient.ini :
windows_flexlm_daemon=perl check_flexlm.pl --port $ARG1$ --vendor $ARG2$
commands in Nagios interface :
windows_flexlm 	$USER1$/check_nrpe -H $HOSTADDRESS$ -c windows_flexlm -a $ARG1$
windows_flexlm_daemon 	$USER1$/check_nrpe -H $HOSTADDRESS$ -c windows_flexlm_daemon -a "$ARG1$" "$ARG2$"
the tricky part is passing the arguments, as always :) but also take care you use the right command with the right syntax :lol:
Thank you !
ps : keep this thread open for a week, maybe I will have another problem like this one
Glad it is working for you now. We'll leave it open for you but if you have a new question, please open a new post so we can keep the issues separated.
