NagiosXI failed to install
bercesm
Post by bercesm »
Hi All,
I've a new virtual machine, with OS CentOS 7.
I've downloaded NagiosXI offline installer from here:http://repo.nagios.com/nagiosxi-offline ... _64.tar.gz
Installed the prerequirities.
Untar the file, which was downloaded.
Ran ./fullinstall in the correct directory
Opened a webbrowser with <server_ip>/nagiosxi
Done the steps
Now I've a webpage, where I can login, but the core nagios files are not in the directories, so I can't use the system.
I cant find install.log as well.
How can I correct this?
I've no commands.cfg in /usr/local/nagios/etc/ but i've nagios.cfg here.
It semms to me, it made the install in an incorrect way. What can I do?
Thanks for the help,
Miklos
Reason: marking with green check mark
Re: NagiosXI failed to install
Can you please upload a profile for us to review? (Admin -> System Profile -> Download Profile)
This will give us a bit of insight as to what's going on.
bercesm
Post by bercesm »
I've attached it.
Now I found that there is no config file in /usr/local/nagios
(commnads.cfg, etc. so Whitch file was missing, I migrated from my test environment.
First I could start nagios engine, but I should restart the machine. Now I have this error:
nagios.service: control process exited, code=exited status=203
Failed to start Nagios Core Monitoring Daemon.
What can I do?
Thanks for the advice!
bercesm
Post by bercesm »
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 12 services.
Checked 1 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 2 contacts.
Checked 2 contact groups.
Checked 124 commands.
Checked 8 time periods.
Checked 0 host escalations.
Checked 1 hosts
Checked 0 host dependencies
Checked 8 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
bercesm
Post by bercesm »
Solved it with:
ln -s /etc/init.d/nagios /usr/lib/systemd/scripts/nagios
Thanks!
Post by dwhitfield »
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
bercesm
Post by bercesm »
Yes.
Thanks, for the helps!
This thread can be locked.
