Is it possible to monitor the age of a text file once per day?
Example:
I have a text file that gets updated once daily (update time will vary), can we set it so that it will constantly check the age of the file and will trigger an alert only if its older than yesterday?
I can't really use file is older than X # of hours since the file will be updated at different times daily.
I hope this make sense.
Daily File Age Check
Re: Daily File Age Check
Some good examples of check_file_age here:
http://sites.box293.com/nagios/guides/c ... es-folders
Why wouldn't a check for say "if older than 24 hours" work?
Here is another plugin which may work, have you seen this one?:
https://exchange.nagios.org/directory/P ... ck/details
Thanks for the links, i'll take a look at it. However, this can be closed since my team decided to go a different route.
