Changing defaults for switch / router wizard?
dfmco
Post by dfmco »
We typically have to make additions and modifications to all of our clients devices as they add and remove services. I have been using the switch / router wizard but it is time consuming to have to input the SNMP V3 options for every device. I would like the Security Level, Username, Auth and Priv passwords, Auth and Priv protocols, Port name (not number), and input and output rates all to be pre-filled with our defaults. This will save a HUGE amount of time when we have to add interfaces to all devices for a client. Is this possible?
Re: Changing defaults for switch / router wizard?
Post by dwhitfield »
We have an internal feature request 7658 which says
user would like the ability for the network switch/router wizard to pull additional settings from the xiwizard_switch_port_status_service template. Right now it pulls some, but not all of them. Please see this thread for details: https://support.nagios.com/forum/viewto ... 60#p170560
Does that sound close enough to what you want, or are you looking for something different? Either way, I do not currently have an ETA on that feature request. It is in the "Pending Approval" stage.
If that is not what you want, we can certainly put in another feature request.
