Hey guys,
I hate to ask this question, but when will you guys be upgrading the ES and Kibana engines? I love NLS, but higherups use the internet, and have been asking why we cant do all the coolness that is on the ES website.
If I could get a timeline (not set in stone ), it will make it way easier to make the case for sticking with NLS and not going to a pure ELK stack. Thanks guys!
Im willing to add if you need a beta tester I' m your man ive got 516 devices sending logs to my server:
holla!
Upgrade road map
Upgrade road map
Reason: marking with green check mark
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
- Former Nagios Staff
Re: Upgrade road map
How does
sound? https://www.nagios.com/roadmaps/ That's not to ES 2, that will beend of February
Q2 of 2017
DAAYYUUMM! that was quick lol! gonna call you lightnin' bro lol thanks!
Proudly running:
Nagios Fusion
Nagios Fusion
hey! Wait a minute! q2 is april 1st. did I just get pre release april fooled ? lol jk lock it up and thatnks for the quick reply!
Proudly running:
Nagios Fusion
Nagios Fusion
Well, it doesn't say day 1 of Q2.
You're welcome. I'll lock it up.
