I have had a problem after a update.
1. the update could not ended, after some time I stopped it.
2. nagios was not able to start, a message ask me to repair the db. I did it.
3. nagios always inaccessible, I restore the last update backup (today backup)
4. after a reboot I can acces to nagiosXI but I have the message "Error: Unable to write to check_result_path ('/usr/local/nagios/var/spool/checkresults') - Permission denied
And everything seems to be ok with the permission on /usr/local/nagios/var/spoolcheckresults
Could you help me ?
regards
Re: Unable to write to check_result_path
Can you share the output of the following commands executed from the CLI of your Nagios XI machine:
ps aux | grep nagios
cat nagios.cfg | grep checkresults
ls -al /usr/local/nagios/var/
ls -al /usr/local/nagios/var/spool
