Warning: Duplicate , but found none.
lout_tie
Post by lout_tie »
hello
I know this problem with duplicate is very common. I try to read through all the posts and helps. But none seems solve my problem
my nagios is in the directory etc/nagios3 and not in /usr/...
using nagios3 -v /etc/nagios3/nagios.cfg
Nagios Core 3.5.1
Last Modified: 08-30-2013
License: GPL
Reading configuration data...
   Read main config file okay...
Processing object config directory '/etc/nagios3/objects/commands'...
Processing object config directory '/etc/nagios3/objects'...
Processing object config directory '/etc/nagios3/objects/templates'...
Processing object config file '/etc/nagios3/objects/templates/generic-service-template.cfg'...
Processing object config file '/etc/nagios3/objects/templates/generic-host-template.cfg'...
Processing object config directory '/etc/nagios3/objects/services'...
Processing object config file '/etc/nagios3/objects/services/services.cfg'...
Processing object config directory '/etc/nagios3/objects/hosts'...
Processing object config file '/etc/nagios3/objects/hosts/host_pi.cfg'...
Processing object config file '/etc/nagios3/objects/hosts/localhost.cfg'...
Processing object config file '/etc/nagios3/objects/hosts/host_test.cfg'...
Processing object config file '/etc/nagios3/objects/contacts.cfg'...
Processing object config file '/etc/nagios3/objects/timeperiods.cfg'...
Warning: Duplicate definition found for service 'generic-service' (config file '/etc/nagios3/objects/templates/generic-service-template.cfg', starting on line 2)
Error: Could not add object property in file '/etc/nagios3/objects/templates/generic-service-template.cfg' on line 3.
     directives and data defintions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
Folder and rights
drwxr-xr-x   5 root root    4096 Feb  1 08:52 .
drwxr-xr-x 117 root root    4096 Feb  1 00:21 ..
-rw-r--r--   1 root root    2109 Okt  5  2014 apache2.conf
-rwxrwxr--   1 root root   12472 Jan 31 09:06 cgi.cfg
-rw-r--r--   1 root root    2443 Mär 15  2016 commands.cfg
drwxr-xr-x   3 root root    4096 Jan 31 10:05 conf.d
-rw-r--r--   1 root root      50 Jan 23 15:07 htpasswd.users
-rw-r--r--   1 root root   44743 Jan 31 15:43 nagios.cfg
drwxrwxrwx   6 root root    4096 Feb  1 08:15 objects
-rw-r--r--   1 root nagios  1293 Jul 29  2011 resource.cfg
drwxr-xr-x   2 root root    4096 Jan  4 12:01 stylesheets
cut outs from my nagios.cfg
# NAGIOS.CFG - Sample Main Config File for Nagios
# LOG FILE
# This is the main log file where service and host events are logged
# for historical purposes.  This should be the first option specified
# in the config file!!!
log_file=/var/log/nagios3/nagios.log
# Commands definitions
cfg_dir=/etc/nagios3/objects/commands
# Debian also defaults to using the check commands defined by the debian
# nagios-plugins package
# Debian uses by default a configuration directory where nagios3-common,
# other packages and the local admin can dump or link configuration
# files into.
# OBJECT CONFIGURATION FILE(S)
# These are the object configuration files in which you define hosts,
# host groups, contacts, contact groups, services, etc.
# You can split your object definitions across several config files
# if you wish (as shown below), or keep them all in a single config file.
#cfg_file=/etc/nagios3/objects/commands.cfg
#cfg_file=/etc/nagios3/objects/contacts.cfg
#cfg_file=/etc/nagios3/objects/timeperiods.cfg
#cfg_file=/etc/nagios3/objects/templates.cfg
#cfg_file=/etc/nagios3/objects/hosts.cfg
# Definitions for monitoring a Windows machine
#cfg_file=/etc/nagios3/objects/windows.cfg
# Definitions for monitoring a router/switch
#cfg_file=/etc/nagios3/objects/switch.cfg
# Definitions for monitoring a network printer
#cfg_file=/etc/nagios3/objects/printer.cfg
# You can also tell Nagios to process all config files (with a .cfg
# extension) in a particular directory by using the cfg_dir
# directive as shown below:
#cfg_dir=/etc/nagios3/printers
#cfg_dir=/etc/nagios3/switches
#cfg_dir=/etc/nagios3/routers
# OBJECT CACHE FILE
# This option determines where object definitions are cached when
# Nagios starts/restarts.  The CGIs read object definitions from
# this cache file (rather than looking at the object config files
# directly) in order to prevent inconsistencies that can occur
# when the config files are modified after Nagios starts.
object_cache_file=/var/cache/nagios3/objects.cache
in conf.d Directory I moved all templates in an extra folder and rename with different ending than .cfg.
The templates that I will use for my other definition I copied to ../objects/templates. I set them all to register 0
The weird thinig is doesnt matter what I do..it seems it doesnt read the cfg at all. It keeps the localhost , the default setting. I can see that in objects.cache.
When I seek for generic-service . I just one with the name as generic-service.. from the templates. Rest of it is just using the template which is alright. Since it should be inherited.
I dont know where I might have configurated it wrong. Much Appreciated!
Re: Warning: Duplicate , but found none.
Please run grep -R 'generic-service' /etc/nagios3/ and post the full result - there is a duplicate somewhere and this should show us.
lout_tie
Post by lout_tie »
 $grep -R 'generic-service' /etc/nagios3/
/etc/nagios3/objects/services/services.cfg:        use                             generic-service
/etc/nagios3/objects/hosts/localhost.cfg:        use                             generic-service         ; Name of service template to use
That's odd, it didn't even pick up on your template file which it mentioned generic-service in. Can you please zip up your entire /etc/nagios3/ configuration directory for us to look at?
lout_tie
Post by lout_tie »
Hello
I was on vacation..Now I recheck my nagios setting... I lost all my original Templates..I cant remember I erased them.
Is there a way to redownload the templates or cfg files that came original in the conf.d folder?
lout_tie
Post by lout_tie »
So I just manually recreated some of the templates files. Just the one I need to check like generic-service and generic-host templates.
I zip my nagios3 folder.
doesnt matter what I do. It doesnt pick up my configuration. I checked even in the init.d . It gets the right folder. I dont even know from where he reads the files.
nagios3_1.zip
(37.93 KiB) Downloaded 265 times
Everything looks fine from what I can tell. Can you try correcting this definition? I could see it messing with things potentially since it's not commented out all the way -
d#efine service{
  #      use                             generic-service         ; Name of service template to use
   #     host_name                       localhost
    #    service_description             Total Processes
#		check_command                   check_procs!250!400
Is starting fresh, on the latest version, an option for you? You're a couple years behind now version wise, and it's hard to say what could be going on with the older version, especially without knowing how it was installed / compiled. We have source instructions that should work fine on a new, clean machine. https://support.nagios.com/kb/article.p ... ategory=58
lout_tie
Post by lout_tie »
I commented out for a test. But whatever I do It doesnt change anything. I just used nagios3 for a test. It could just apt-get install nagios latest version. But it should have worked regardless nagios3 oder nagios4 or not? I dont know what I messed up. But I think the only option for me is to uninstall nagios and restart
Post by dwhitfield »
You're unlikely to get the latest version from apt-get. My Debian box doesn't have Nagios Core 4 in the repos at all. The best thing to do would be to compile from source: https://support.nagios.com/kb/article.php?id=96
Now, if you want to stay on your current nagios3, I'd be curious the output of find / -name nagios.cfg.
lout_tie
Post by lout_tie »
bascially it didnt find anything useful. Most indicate /var/lib/lxcfs/cgroup /... something then : No authority
I dont think this is the problem.
