Problem MySQL when run "backup_xi" - nagios_logentries crash
redesgtt
Post by redesgtt »
I am trying to run "backup_xi.sh" before upgrade up to 5.4.1 our Nagios XI (now we have 5.4.0).
When I run backup_xi.sh, it shows:
[root@nagiosxi nagiosxi]# /usr/local/nagiosxi/scripts/backup_xi.sh
Backing up Core Config Manager (NagiosQL)...
tar: Eliminando la `/' inicial de los nombres
Backing up Nagios Core...
tar: /usr/local/nagios/var/rw/nagios.qh: el `socket' no se tendrá en cuenta
tar: /usr/local/nagios/var/ndo.sock: el `socket' no se tendrá en cuenta
tar: /usr/local/nagios/var: el fichero cambió mientras se estaba leyendo
Backing up Nagios XI...
Backing up MRTG...
Backing up NRDP...
Backing up Nagvis...
Backing up MySQL databases...
mysqldump: Got error: 144: "Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed" when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!
tail -50 /var/log/mysqld.log
tail: no se puede abrir «/var/log/mysqld.log» para lectura: No existe el fichero o el directorio
(in english: mysqld.log doesn't exist)
Well, the unique different thing we have changed this week is add mklivestatus, and we have two "broker_module" lines in the nagios.cfg now, such that:
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
broker_module=/usr/local/lib/mk-livestatus/livestatus.o /var/nagiosramdisk/rw/mklive
I just see next post with the same problem:
https://support.nagios.com/forum/viewto ... 6&start=10
it appears wasn't solved by support Nagios or ¿yes?
should I do all shown in that post?
we have Nagios XI Enterprise with Mail support too.
Please, let me know how repair this problem.
Regards.
Re: Problem MySQL when run "backup_xi" - nagios_logentries c
You'll need to repair your mysql database -
/usr/local/nagiosxi/scripts/repair_databases.sh
After that, attempt to backup again, and it should work properly.
As for mk_livestatus - this isn't our product, and Support is limited on the help we can provide with that NEB module running.
redesgtt
Post by redesgtt »
hi,
thanks, the issue has been resolved with "repair_databases.sh", I can do backup now.
You can close the post.
Glad to hear that fixed it! Closing this one out.
