If I now select one of the "topics" in either "Host Status Totals" or "Service Status Totals" at the top of the page I only get the following:
"It appears as though you do not have permission to view information for any of the hosts you requested..."
If I, instead of searching, select "Hosts" and then click on "View Service Details For This Host". I I then select one of the "topics", E.g. "All Problems" under "Service Status Total", everything works as expected.
I am logged in with my user "dajoha" (ldap authenticated) which has "superuser" rights in cgi.cfg
# egrep -v "^(#|$)" cgi.cfg
main_config_file=/etc/nagios/nagios.cfg
physical_html_path=/usr/share/nagios/html
url_html_path=/nagios
show_context_help=0
use_pending_states=1
use_authentication=1
use_ssl_authentication=0
authorized_for_system_information=nagios,dajoha
authorized_for_configuration_information=nagios,dajoha
authorized_for_system_commands=nagios,dajoha
authorized_for_all_services=nagios,dajoha
authorized_for_all_hosts=nagios,dajoha
authorized_for_all_service_commands=nagios,dajoha
authorized_for_all_host_commands=nagios,dajoha
default_statusmap_layout=6
default_statuswrl_layout=4
ping_syntax=/bin/ping -n -U -c 5 $HOSTADDRESS$
refresh_rate=90
result_limit=100
escape_html_tags=1
action_url_target=_blank
notes_url_target=_blank
lock_author_names=1
navbar_search_for_addresses=1
navbar_search_for_aliases=1Any suggestions on what I could have done wrong?
