Host Status Pending
Gh0stRyd3r
Host Status Pending
I have been running my Core 4.2.4 for several weeks now with a small set of Cisco switches and after updating the config to include all of our switches the Host status has been in pending for the newly added switches for days. If I view from Services all the checks return with OK status and are updating fine. I attempted to purge the retention.dat and now all the host are in pending status(switches, localhost, and windows servers).
Re: Host Status Pending
What exactly did you do? This isn't generally something we recommend.I attempted to purge the retention.dat and now all the host are in pending status(switches, localhost, and windows servers).
You may just need to restart the nagios process in order for it to re-write things out properly.
Gh0stRyd3r
This is what I did and I restarted the services since then. They have been up for over 3hrs and when it reaches the next Host Check schedule it just makes a new one for 1-2 minutes out past the missed/failed Check.
Can you post a few things for us to review?
- nagios.cfg
- nagios.log
- The host definition for the check that is doing this.
- nagios.cfg
- nagios.log
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
Gh0stRyd3r
Sorry for the delay other projects pulled me away, I've attached the two I know what your asking for as far as host definitions are you meaning the switch.cfg I'm using to populate the list of items to be monitored?
I added the "host" files in case and just using the default commands. I see all of these working on the service tab its only on the Host tab it still says Pending with 32 days attempting.
switch.cfg- (48.56 KiB) Downloaded 400 times
nagios.cfg- (43.94 KiB) Downloaded 368 times
nagios.log- (41.93 KiB) Downloaded 366 times
It appears as though your host objects themselves don't have any check_command defined:
This would explain why the host objects are all in a "pending" state; They don't have a check_command to run. This by itself isn't necessarily a problem since you've got some services defined under the host doing richer health assessment. Most users will use a simple ping check for their host's check_command.
host_name GRN_MDF ; The name we're giving to this switch
display_name Cisco 6509-E Chasis ; A longer name associated with the switch
alias MDF Switch
max_check_attempts 5
contact_groups admins
address 172.19.182.2 ; IP address of the switch
hostgroups switches ; Host groups this switch is associated with
}Former Nagios employee
Gh0stRyd3r
Well second dumb mistake. Thanks for the help was beating my head against a wall to figure out what I did wrong.
Was there anything else we can help with on this thread or are we okay to close it?
