capture show track - Last change uptime via SNMP
zaji_nms
Post by zaji_nms »
Dear Expert
Please give some guide line (OID) how to capture below show track status via SNMP. As a parameter we will send track ID, which is here = 5
If you able to give hint to fetch all the values very good, however our main concern is "last change 19:51:43", how to fetch via SNMP this Last Change Time.
CiscoRouter#show track 5
Track 5
IP SLA 5 reachability
Reachability is Up
2 changes, last change 19:51:43
Latest operation return code: OK
Latest RTT (millisecs) 4
Regards
Re: capture show track - Last change uptime via SNMP
Have you tried using the SNMP walk wizard at all? This will allow you to map the variable to a field, if it's available via SNMP.
Can you show us the full output of a SNMPwalk against the router? We'll be looking to find the MIB/OID for the applicable data.
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up?
