I'm following the document on how to install the Nagios client on macOS (in this case, the version is 10.12.3). I have XCode with command Line Tools installed. I tried running the bash script for fullinstall like it instructs both using sudo preceding the command and sudo -i. This is what I get.
Current step is 0-usersgroups
./fullinstall: line 36: ./0-usersgroups: Permission denied
0-usersgroups appears to have already completed successfully. Moving on to the next step.
Current step is 1-services
./fullinstall: line 36: ./1-services: Permission denied
1-services appears to have already completed successfully. Moving on to the next step.
Current step is A-subcomponents
./fullinstall: line 36: ./A-subcomponents: Permission denied
A-subcomponents appears to have already completed successfully. Moving on to the next step.
Starting NRPE Agent
### Nagios Mac OSX Agent Installation Complete! ###
If you experience any problems, please attach the file logs-all-steps-1486410377.tar.gz that was just created to any support requests.
Permissions issues tell me these scripts didn't run. What are the permissions supposed to be so I can double-check them? What else could be causing such problems?
The log file it mentions is attached.
Thank you!
Reason:marking with green check mark
1. Are the files executable? Please show us the full output of ls -la ran from that folder.
2. I don't have a Mac here to test with, but what happens if you append sudo to line 36 like this? I'm wondering if this will affect it.
I had another look at the scripts and it turns out that the properties on the scripts changed upon extracting them from the tar.gz file. I'm not sure how.
I downloaded the client install again. It seems to work.
