Update column widths in 5.4
gormank
Post by gormank »
I have (well, stole from here no doubt) the following command that updates column widths. It works in my old 2.6 systems, but not in the new 5.4. Can you help update it for 5.4?
echo "use nagios;alter table nagios_servicestatus modify output varchar(1024) not null;alter table nagios_servicestatus modify long_output varchar(1024) not null;alter table nagios_servicestatus modify perfdata varchar(1024);" | mysql –pnagiosxi
Re: Update column widths in 5.4
Is this what you're looking for by chance?
https://support.nagios.com/kb/article.php?id=478
gormank
Post by gormank »
Perfect.
Close this anytime.
Thanks!
