Hi Everyone,
Can you please help with the issue related to check_nrpe socket timout?
nagios Server: systemb (RHEL6.2) (10.146.1.100)
nagios Host: systema (Solaris 10) (10.146.1.37)
I tired all the solution provided by standard troubleshooting guideline but still facing the socket timeout issue.
1. Increase Socket Timeout: “connection_timeout=300” and ommand_timeout=60 seconds
2. restart service at server machine: service xinetd status/stop/start
3. check nrpe process: ps -aef | grep nrpe
4. port setting are enabled at both the ends.
Issue I'm facing:
On server machine: 10.146.1.100
command: /usr/local/nagios/libexec/check_nrpe -H 10.146.1.37
Output is : CHECK_NRPE: Socket timeout after 30 seconds.
On host machine: 10.146.1.37
command: /usr/local/nagios/libexec/check_nrpe -H 10.146.1.100
Output is: NRPE v2.14
Please provide me solution for this one directional connection issue?
Also let me know what additional settings/configurations needed to be done to resolve this issue?
Regards,
Nikhil
nikhildhule
Re: CHECK_NRPE: Socket timeout after 30 seconds.
Output is : CHECK_NRPE: Socket timeout after 30 seconds.From the host machine, what is the output of these commands?
netstat -nap
ps -ef | grep nrpe
nmap 10.146.1.37
nikhildhule
Please find the output of the following commands
On Host:
root@ssbpEch03:/# netstat -nap
Net to Media Table: IPv4
Device IP Address Mask Flags Phys Addr
vnet0 224.0.0.22 255.255.255.255 01:00:5e:00:00:16
vnet0 10.146.1.31 255.255.255.255 o 00:14:4f:fb:f2:f8
vnet0 10.146.1.23 255.255.255.255 00:14:4f:fb:26:63
vnet0 10.146.1.13 255.255.255.255 o 00:14:4f:f8:b7:ea
vnet0 10.146.1.1 255.255.255.255 o 00:10:db:ff:20:60
vnet0 10.146.1.121 255.255.255.255 o 00:14:4f:fb:26:63
vnet0 10.146.1.122 255.255.255.255 o 00:14:4f:fb:c5:2f
vnet0 10.146.1.100 255.255.255.255 o 00:21:28:bc:10:10
vnet1 10.127.8.44 255.255.255.255 SPLA 00:14:4f:fb:8f:f5
vnet0 10.146.1.35 255.255.255.255 o 00:14:4f:f9:ef:6a
vnet1 10.127.63.246 255.255.255.255 18:ef:63:e9:9b:c2
vnet0 10.146.1.37 255.255.255.255 SPLA 00:14:4f:fa:61:de
vnet1 10.127.63.245 255.255.255.255 o 00:00:0c:07:ac:7f
vnet1 224.0.0.0 240.0.0.0 SM 01:00:5e:00:00:00
vnet0 224.0.0.0 240.0.0.0 SM 01:00:5e:00:00:00
root@ssbpEch03:/# ps -ef | grep nrpe
nagios 2596 410 0 03:54:11 ? 0:00 nrpe -c /usr/local/nagios/etc/nrpe.cfg -i -n
root 2613 2443 0 03:54:40 pts/1 0:00 grep nrpe
nagios 2598 410 0 03:54:30 ? 0:00 nrpe -c /usr/local/nagios/etc/nrpe.cfg -i -n
nagios 2597 410 0 03:54:22 ? 0:00 nrpe -c /usr/local/nagios/etc/nrpe.cfg -i -n
nagios 2611 410 0 03:54:40 ? 0:00 nrpe -c /usr/local/nagios/etc/nrpe.cfg -i -n
on server machine:
nmap 10.146.1.37 does not work
bash-4.1# nmap 10.146.1.37
-bash: nmap: command not found
On Host:
on server machine:
Could you please answer my question? I was asking about your logic here.
Secondly, I don't know Solaris very well, but could you verify that the host machine is listening on port 5666 and show us? Also, please post /usr/local/nagios/etc/nrpe.cfg for us to review.Is there a reason you're trying to query the host from the server? Generally speaking, the host will just be reaching out to poll the client. I just want to make sure you understand the use of NRPE properly. It appears to be working fine from your host machine to the client, which is what I'd expect.
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
