I am using performance graph for my Service.
The graph generated is the concurrent calls on the server and they are sent every 5min.
Now when I check the graph on NAGIOS it is showing decimal values on like 14.43 which is impossible to have.
how can I have the right values instead of the average?
Nagios Graph
Nagios Graph
Re: Nagios Graph
The averaging is what comes with using RRD files to store the data - there isn't a way around this unfortunately.
Re: Nagios Graph
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
Re: Nagios Graph
Apologies I haven't been checking my nagios forum lately. I got my answer from this post, this can be closed! thanks you
Re: Nagios Graph
I'll be closing this thread now, but feel free to open another if you need anything in the future!
