when running service nagios restart on nagios server
i have newly added this server in the nagios server and iam facing this issue please help me when i am making mistake
[root@nblnxora003d objects]# service nagios restart
Running configuration check...
Nagios Core 4.1.0rc2
Copyright (c) 2009-present Nagios Core Development Team and Community Contributo rs
Last Modified: 07-17-2015
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for host 'dclnxspl007a' (config file '/usr/local/nagios/etc/objects/hostname.cfg', starting on line 24)
Error: Could not add object property in file '/usr/local/nagios/etc/objects/hostname.cfg' on line 28.
24 define host{
25 use linux-server ; Name of host template to use
26 ; This host definition will inherit all variables that are defined
27 ; in (or inherited by) the linux-server host template definition.
28 host_name hostname
29 alias hostname
30 address 10.XX.XX.XXX
31 }
32
Re: when running service nagios restart
It appears you have two host definitions for 'dclnxspl007a' - I would run a grep -R 'dclnxspl007a' /usr/local/nagios/etc/ and see if that points to where the other place it's defined.
vyasdevaguddi
i have attached the nagios screenshot and i getting 255 bounds and as shown in error message
Please create your own thread for this problem with more information on the service definitions.vyasdevaguddi wrote:i have attached the nagios screenshot and i getting 255 bounds and as shown in error message
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
