Hi I received following error message:
• An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
Try Again
Error: Could not find any host matching 'nagios' (config file '/usr/local/nagios/etc/services/nagios.cfg', starting on line 336)
Error: Failed to expand host list 'nagios' for service 'Total Service Problems' (/usr/local/nagios/etc/services/nagios.cfg:336)
while trying to fix it using instructions from "article: 144 Nagios XI - Configuration Verification Failed:"
Error: Could not find any host matching 'af-admin01.af.local' (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 70)
Error: Could not expand members specified in hostgroup (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 70)
Nagios Core 4.2.4
Last Modified: 12-07-2016
License: GPL
Reading configuration data...
Read main config file okay...
Please Help resolving this issue.
Nagios XI Config Error
Re: Nagios XI Config Error
As the error mentions, it would appear you have the host af-admin01.af.local defined in a hostgroup, in the hostgroups file. I would take a look here, and remove the host. When you remove a host, you also need to remove the relationships that go with it.
The issue is resolved
