Hello Support,
The hosts configured on my NagiosXI suddenly are not appearing and my console page is grayed out. I still get status notifications about them on my email though. Find attached a screen shot of the nagiosxi landing page with specific reference to the SQL error message being displayed:
SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_hoststatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_hoststatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_hoststatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_hoststatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_hoststatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_hoststatus' SQL: SQL Error [ndoutils] : Incorrect file format 'nagios_hoststatus'[/b][/i][/b][/i][/u]
All Host on NagiosXI disappeared_grayed out
venturegardengroup
Re: All Host on NagiosXI disappeared_grayed out
You'll want to repair the database with the following script.
If you persist to see the Incorrect file format error, then following the remaining instructions on this guide - https://assets.nagios.com/downloads/nag ... tabase.pdf - that mentions -
/usr/local/nagiosxi/scripts/repair_databases.sh
If you receive an error, similar to this one:
Error : Incorrect file format 'nagios_systemcommands'
error : Corrupt
you will need to execute the following command to fix the table:
venturegardengroup
Thanks for the support, I was able to restore with an earlier backup and all was working fine. Thanks.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
