Comparison XI discovery vs BMC network discovery
strmon
Post by strmon »
Just wanted your input on "Comparison XI discovery vs bmC network discovery". Can u suggest any plugin which can be used with nagosxi -discovery to gain features like bmc network discovery ? Suggest.
Re: Comparison XI discovery vs BMC network discovery
I'm not familiar with BMC, so you may need to do a bit of research for what it provides.
The auto discovery feature we have scans the subnet you specified using a nmap query. From there, it determines what ports are open, and allows you to monitor them with simple checks.
Is this what you were looking for?
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
