Nagios Images
matei1982
Nagios Images
Post by matei1982 »
Hi.
I'm tring to add the Operating System Logo to every defined host (see the images) and everything is ok :
name ESXi-server
use generic-host
check_period 24×7
check_interval 5
retry_interval 1
max_check_attempts 10
Now i would line add an another image but it doesn't work!! Do you know how change the configuration file?
Thanks.
Re: Nagios Images
Are you trying to add multiple icons to a host, or change it from the default Windows one you specified?
matei1982
Re: Nagios Images
Post by matei1982 »
Hi. I'm trying to add multiple icons to a host.
Re: Nagios Images
matei1982 wrote:Hi. I'm trying to add multiple icons to a host.
I don't believe this is currently possible. Though, I imagine it's worth filing a request for. Please create one over on GitHub @ https://github.com/NagiosEnterprises/nagioscore/issues
Re: Nagios Images
Just checking in since we have not heard from you in a while. Did @rkennedy's post clear things up or has the issue otherwise been resolved?
