sending logs from a chromebook
benhank
Post by benhank »
Di you guys know of a way to have a chromebook send its logs to the NLS?
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: sending logs from a chromebook
Is there any sort of syslog agent for the machine to use that allows you to forward logs somewhere?
It appears they're located at /var/log still, but I can't find anything online mentioning how to poll them every so often. I did find these links -
http://www.dell.com/support/article/us/ ... N288529/pl
https://toolbox.googleapps.com/apps/loganalyzer/
benhank
Post by benhank »
thanks man! ill look into the links you can lock this
Proudly running:
Nagios Fusion
Post by dwhitfield »
What model/brand of Chromebook do you have? I found the same Dell link @rkennedy found, but wasn't sure if it would apply.
That said, if you're happy with us locking it up, I'm happy to lock it up. :)
