Hi
I was recently on version 1.6 and upgraded to 1.7 where it crashed the system.
So i have started again from the 1.8 image. I am having two issues however with this version.
1. The windows hosts are reporting Connection refused. I can telnet on port 5666 from the server to nagios and 12489 from nagios to the server. Is there anything else i should look out for?
2. The routers that are reporting back via SNMP are not reporting anything in the bandwidth. Not even 0mbps, just blank. When I run an snmp walk, the out octets are increasing. OK - Current BW in: Mbps Out: Mbps
Would it have anything to do with snmp version 2c rather then 2? As you cant select 2c in this version
Any help will be greatly appreciated as i want to get this system back up and running.
thanks
r1.8 bandwidth and connection refused
Re: r1.8 bandwidth and connection refused
Has the IP address or hostname changed? Perhaps the NSclient configs and SNMP ACL's are not allowing the new server access.
I managed to fix 1. Didnt setup my DNS settings correct.
But i am still having issues with the bandwidth reporting.
I have checked the SNMP ACLs and the IP is still correct as the host IP is still the same
thanks
thanks
when i run the check_rrdtraf i get the following
[root@pacsysmon libexec]# ./check_rrdtraf -f '/var/lib/mrtg/10.131.32.1_1.rrd' -w 1,1 -c 2,2 -l M
./check_rrdtraf: line 315: bc: command not found
OK - Current BW in: Mbps Out: Mbps./check_rrdtraf: line 316: bc: command not found
|in=Mb/s;1;2 ./check_rrdtraf: line 317: bc: command not found
out=Mb/s;1;2
You have new mail in /var/spool/mail/root
is this file different in 1.8?
out=Mb/s;1;2
Do you have bc installed? Try running in terminal:
# yum install bcBe sure to check out our Knowledgebase for helpful articles and solutions!
thanks, that has resolved my issue
Glad, I could help!
