Hi all.
We are trying to speed up our Nagios WebGUI and have done just about everything we can to achieve this.
We have an environment where we have one main Nagios server and all checks are done by 6 mod_gearman nodes.
So our main Nagios server isn't really doing any checks, its just accepting the check results and processing them.
We have moved our main Nagios server to an all flash VM environment for faster disk access.
The number of CPUs has been doubled from 2 to 4
There is 24G RAM and 50G swap
But the WebGUI isn't a quick as some people would like.
We are monitoring around 2500 hosts and 15000 services, all of which are done on mod_gearman nodes
We are running Nagios Core 4.2.4.
The main load seems to be when people are access status.cgi for check info and submitting commands from the GUI.
Running top and watching the individual CPUs I can see most are running at about 30%, then they will jump to 90% and the process on the stop is status.cgi.
We have a lot of people accessing the WebGUI which is why this is happening.
Just wondered if anyone has found a way of load balancing Nagios across more than one server and still have identical information in the output of the WebGUI and are able to run commands from the GUI.
Or if anyone had any suggestions?
Tony
Load Balancing WebGUI
Re: Load Balancing WebGUI
I would look into a ramdisk at the very least: https://assets.nagios.com/downloads/nag ... giosXI.pdf
This will help speed up a lot of those CGI calls that parse out the status files. The doc is for an XI install, but is adaptable to Core as well.
Aside from that, I would consider throwing a bit more CPU at the machine if you are going to have a lot of people using the interface at once, though I think the ramdisk is likely to provide more benefit.
- Former Nagios Staff
In addition to what @tmcdonald said, have you looked at https://httpd.apache.org/docs/2.4/misc/perf-tuning.html ? Now, you might not be using Apache, but server optimization is still something in which I'd be interested.
Also, I want to additionally highlight the more CPU. We don't know anything about how fast those 4 CPUs are either.
Also, you don't mention what OS you are running. There might be some OS performance tweaks.
Lastly, while it doesn't help you now, Core 4.3 (set for April) has
more info at https://www.nagios.com/roadmaps/Performance enhancements to the status.cgi
delboy1966
Apologies, I did miss some information out as you indicated.
Centos 6.7
CPU: 4 x Intel(R) Xeon(R) CPU E5-2680 v3 @ 2.50GHz
Apache 2.2.15
Thank you for your advise.
I used to use Ramdisk until we migrated the server to pure flash disks, but have added it again to see if it makes any difference.
Apache is optimized as far as my knowledge allows me to optimize it without breaking anything.
I look forward to the arrival of 4.3
Thanks again.
Centos 6.7
Apache 2.2.15
Thanks again.
I also wonder if something like Varnish would help. It's not going to help the cgi issues specifically, but if it's really just being slammed by multiple users it might help.
Do you want us to go ahead and lock this up, or leave it open and you can report back after 4.3 is out? You can obviously report back either way...just in a different thread under one of the options.
delboy1966
Thanks I will take a look at Varnish.
Yes please lock the thread and I will see how 4.3 performs when its out.
Thanks again
Thanks again
