Check_nrpe returns no output
kwhogster
Post by kwhogster »
Guys
This one again but a different flavor
My service
        host_name               TGCS011
        service_description     NSClient++ Version
        servicegroups           nsclients
        check_command           check_nrpe
My command
        command_name    check_nrpe
        command_line    /usr/lib/nagios/plugins/check_nrpe -H $HOSTADDRESS$ -t 60 -c $ARG1$ $ARG2$ $ARG3$ $ARG4$
In Nagios
TGCS011 NSClient++ Version UNKNOWN 02-18-2017 22:41:40 0d 0h 16m 32s 3/3 (No output returned from plugin)
When I run it from command line it works
root@tgcs017:/usr/local/nagios/etc/objects# /usr/lib/nagios/plugins/check_nrpe -H TGCS011 -t 30 -4
I (0,4,1,73 2012-12-17) seem to be doing fine...
All my other check_nrpe commands are working on this same computer ;) ;)
Any ideas?
avandemore
Re: Check_nrpe returns no output
Post by avandemore »
Your plugin is only returning perf data? Typically a plugin with return more than just perf data:
[[email protected] ~]$ /usr/local/nagios/libexec/check_ping -H 127.0.0.1 -w 100.0,20% -c 500.0,60% -p 5
PING OK - Packet loss = 0%, RTA = 0.02 ms|rta=0.023000ms;100.000000;500.000000;0.000000 pl=0%;20;60;0
Here is some information on plugins:
https://nagios-plugins.org/doc/guidelines.html
https://mathias-kettner.de/checkmk_localchecks.html
http://www.yourownlinux.com/2014/06/how ... cript.html
Previous Nagios employee
kwhogster
Post by kwhogster »
Why giving my a check_ping command
Not that
I am looking to see why check_nrpe does not work from my service definition
It runs fine from the command line.
All my other check_nrpe commands work
Try running it WITHOUT the -c over the command line, my guess is by passing this, it assumes a command. You may want to create a custom command for check_nrpe_version. (just an example)
kwhogster
Post by kwhogster »
Rkennedy
good call that fixed it
This one can now be locked.
