Nagios Engine not Starting
venturegardengroup
Post by venturegardengroup »
My Nagios Engine refused to start... I think I started having this issue once I tried to add a new nagios user. See error screenshots attached:
Regards,
avandemore
Re: Nagios Engine not Starting
Post by avandemore »
Do you have that contact defined?
Please try this:
XI > Configure > Core Config Manager > Config File Management > Delete Files > Write Configs > Verify Files > Restart Nagios Core
Older Nagios Versions:
XI > Configure > Core Config Manager > Write Config Files > Delete > Write > Verify > Restart
Previous Nagios employee
venturegardengroup
Please see output attached from following the steps you recommended.
Regards.
NagiosXI version 5.2.3
CentOS 7, 64bits
32 or 64bit?
Manual Install
venturegardengroup
Missed the attachment. Please find.
avandemore
It's saying you have a host group referencing a non-existent host called Bandwidth_Mgr_Svr. Is that true? If so you should remove the reference. Otherwise you can revert to a previous known good snapshot if you wish.
venturegardengroup
Please can you give me a guide on how to remove the reference?
Thanks.
avandemore
XI > Configure > CCM > Host Groups > [Host group] ] > Manage Hosts. One of the hosts listed is called Bandwidth_Mgr_Svr, it should be removed.
Also you could attach or PM XI > Configure > CCM > Configuration Snapshots > most recent Config Error snapshot if you want confirmation of exactly where the change needs to happen.
ssax
Dreams In Code
Post by ssax »
First, go to Configure > Core Config Manager > Hosts and validate whether that host actually exists in the CCM.
If it's disabled, activate it, and then try to apply configuration.
If it's disabled and/or missing and you don't want to add it back in, please go to Configure > Core Config Manager > Tools > Write Config Files
- Click Delete (don't worry, it's safe, they get re-written)
- Click Write
- Now go edit your /usr/local/nagios/etc/hostgroups.cfg file and search for the host Bandwidth_Mgr_Svr and note the name(s) of the hostgroups that it's in.
- Go to Configure > Core Config Manager > Host Groups
- Edit each one of the hostgroups that you noted above, click the Manage Hosts button, either remove the host from the right hand side OR if it's not listed on the right, just click the Close button, then click the Save button.
- This will force the backend DB info to be rewritten for those hostgroups
- Now try to apply configuration again and let us know the results.
If you would like help determining it, we need to get the files in a bad state so that we can find all of the issues, please perform these steps without any additional steps (like applying config, etc) in between.
Please go to Configure > Core Config Manager > Tools > Write Config Files
- Click Write
- Now zip up your entire /usr/local/nagios/etc directory and PM it to one of us so that we can review it.
zip -r /tmp/NAGIOSCONFIGS.zip /usr/local/nagios/etc/
Thank you
venturegardengroup
I couldn't find Bandwidth_Mgr_Svr in any of the hostgroups, however, I have attached the most recent config snapshot and the zip file for your analysis and help.
Thanks.
Mod Edit: Files received and placed on shared drive
ssax
Dreams In Code
Post by ssax »
- Click Write
- Click the Verify button and post the entire output
Then run this tail command (and let it run):
tail -F /usr/local/nagiosxi/var/cmdsubsys.log
Then apply configuration and send the full output of the tail command after it fails.
Thank you
