Check on IBM Server through IMM
sth_bytelab
Post by sth_bytelab »
HI
We have a couple of IBM servers that we would like to monitor with nagiosXI.
All of the servers have a IMM layer for management is there a way to monitor the servers through it?
I have seen there has been a plugin in for one of the previous-versions of nagios, is there a new plugin or is it not necessary?
Thanks!
avandemore
Re: Check on IBM Server through IMM
Post by avandemore »
What plugin were you looking at?
Previous Nagios employee
Post by dwhitfield »
suspect it's https://exchange.nagios.org//directory/ ... rb/details but let us know if I'm wrong!
sth_bytelab
I was actually looking at this one: https://exchange.nagios.org/directory/P ... sh/details
But i don't think it is working in the XI-version.
That plugin looks like it should work with Nagios XI. Give it a try and if you have any questions go ahead and post them here.
The "Compatible With" section is what the Author / uploader of the plugin ran it on, it doesn't mean that it will not work with newer versions of Nagios.
sth_bytelab
I have now tried the plugin but it doesn't seem to work properly.
I have done a simple health-check:
But I get: "Health status: Unknown"
The plugin looks like it is running but it cannot poll the device.
In the script, the Health status is checked by running the following command.
snmpwalk -v 1 -c community -On 10.0.2.122 .1.3.6.1.4.1.2.3.51.3.1.4
It is trying to poll the device with that OID using SNMP Version 1. Can you run the above command and post it here?
The unknown can be caused by the device is not setup to be polled using SNMP Version 1, or that the community string is incorrect or that the device is not setup at all to be polled by SNMP.
Check the device and see if it is setup to be polled.
Also, run the following command which uses SNMP Version 2 to poll the device. Most newer devices stopped enabling version 1 of SNMP and switched over to version 2.
snmpwalk -v 2c -c community -On 10.0.2.122 .1.3.6.1.4.1.2.3.51.3.1.4
If this works, you would have to edit the script and change the -v 1 options to -v 2c and then the plugin should work.
sth_bytelab
I have tried running snmp -v 1 -c community -On 10.0.2.122 .1.3.6.1.4.2.3.51.3.1.4 and I recieve "Timeout: No Response from 10.0.2.122"
And I get the same response if I am using version 2c.
I have opened all ports in the firewall between the to servers and I have successfully pinged the IMM, so there are a connection between Nagios and the IMM.
Any piece of advise?
Please post your /etc/snmp/snmpd.conf (or whatever the IBM server uses for SNMP management). Even if all the ports are open, SNMP still needs to allow the particular server. You can allow address blocks using a syntax like rocommunity public 10.10.0.0/16
sth_bytelab
OKay, I have now enabled all SNMP:
And set the community to the IP address of nagios.
I have enabled all SNMP traps.
I have tried both doing af snmpwalk through the terminal and a ibm imm check but without any luck. I still recieve Timeout no reply from 10.0.2.122.
