Sometimes in Nagios Core I found very useful the menu:
Configuration --> View Config
http://<IP of nagios CORE>/nagios/cgi-bin/config.cgi?type=hosts
There is the same, or similar, menu on Nagios XI?
I did not found any equal menu under:
http://<IP of Nagios XI>/nagiosxi/includes/components/ccm/xi-index.php
Nagios XI Version : 2014R2.7
Nagios CCM: 2.3.3
P.S. The nagios CORE where I use config.cgi is v3.0.6
menu "view config"
Re: menu "view config"
So if you're looking to see a list of all services appointed to a host, the XI equivalent is here:
CCM - > Hosts > on the right in the Actions column click the blue 'i' to see all relationships. A pop-up window should appear, clcik the appropriate tab.
Just checking in since we have not heard from you in a while. Did @bwallace's post clear things up or has the issue otherwise been resolved?
