Hi
i have a strange problem
i have installed nsclient on my windows server and add this server to my first nagios server and all of things are ok and work perfect then i disjoin this server from nagios one and add to second nagios but now on second nagios show unknow and (No output returned from plugin)
this error appear
UNKNOWN (for 0d 18h 45m 7s)
Status Information: (No output returned from plugin)
NRPE Plugin for Nagios
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 2.15
Last Modified: 09-06-2013
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher required
\nUsage: check_nrpe -H <host> [ -b <bindaddr> ] [-4] [-6] [-n] [-u] [-p <port>] [-t <timeout>] [-c <command>] [-a <arglist...>]
\nOptions:
-n = Do no use SSL
-u = Make socket timeouts return an UNKNOWN state instead of CRITICAL
<host> = The address of the host running the NRPE daemon
<bindaddr> = bind to local address
-4 = user ipv4 only
-6 = user ipv6 only
[port] = The port on which the daemon is running (default=5666)
[timeout] = Number of seconds before connection times out (default=10)
[command] = The name of the command that the remote daemon should run
[arglist] = Optional arguments that should be passed to the command. Multiple
arguments should be separated by a space. If provided, this must be
the last option supplied on the command line.
\nNote:
This plugin requires that you have the NRPE daemon running on the remote host.
You must also have configured the daemon to associate a specific plugin command
with the [command] option you are specifying here. Upon receipt of the
[command] argument, the NRPE daemon will run the appropriate plugin command and
send the plugin output and return code back to *this* plugin. This allows you
to execute plugins on remote hosts and 'fake' the results to make Nagios think
the plugin is being run locally.
and this is my config file for host and services
use windows-server
host_name npmbdlsrv
alias Download Server Mobile Bank
address 10.x.x.x
use 15minute-service
host_name npmbdlsrv
service_description Cpu Usage
check_command check_nrpe!alias_cpu
host_name npmbdlsrv
service_description Disk Space
check_command check_nrpe!alias_volumes
use local-service
host_name npmbdlsrv
service_description Time
check_command check_nrpe!check_windows_time
BR
