Nagios Host/Service Templates
rbuckle
Post by rbuckle »
Good morning,
My network has a lot of pieces of the same equipment, with the same services, same brand etc....
It is possible to create a host template with services, example would be a switch, to add a new switch to nagios of the same make/model you would just have to select the "HOST Template" and it would already create/have the services template for what you want monitored.
I would then be able to create 1 template for 300 or so devices that can be edited/updated/added to without having to create the host and then 10 services for EACH ONE.
If more clarification of what i am asking is need, just let me know.
Running:
Installed Version: 5.8.3
OS: CentOS 7
Nagios XI
Enterprise License
Re: Nagios Host/Service Templates
Post by dwhitfield »
Yes, under the CCM, on the left panel, under templates, you will see Host Templates and Service Templates.
More info at https://assets.nagios.com/downloads/nag ... gement.pdf
If that's not what you want, please describe what you want in more detail.
gormank
Post by gormank »
I use hostgroups to do exactly what you ask. I also use host and service templates to keep monitoring info out of host and service definitions. Hostgroups are attached to services, and when a host is added to a hostgroup, the host monitoring is already configured.
For clarity, the document I provided above also discusses hostgroups.
rbuckle
Post by rbuckle »
what i am asking is, is it possible to have 1 "group" of services for a device type.... then i could:
Template
{SERVICE GROUP} == RSSI,BANDWIDTH,STATUS,PING
Host Association
{HOST} + {SERVICE GROUP}
and nagios will automatically create a host with the listed services
Host - RSSI
- BANDWIDTH
- STATUS
- PING
Running:
OS: CentOS 7
Nagios XI
Enterprise License
gormank
Post by gormank »
Nagios creates no hosts automagically. You can do it in puppet for example.
Can you provide the config/files where said syntax is defined?
While the logic is somewhat different, what you ask for is provided by hostgroups.
Post by mcapra »
As @gormank pointed out, what you are trying to do is possible with host groups.
Say I have the following devices with common services:
  • LAMP application servers
    • Apache
    • MySQL
  • MEAN application servers
    • Node
    • MongoDB
  • Cisco SG300 Switches
    • Common SNMP bandwidth checks for bandwidth
    • An OID for a super secret Cisco metric
    • Temperature, system metrics, etc
  • Windows Servers
    • C: Drive Check
    • CPU/MEM checks
    • IIS Application Pool Checks
If I wanted to save myself the time of hand-configuring the following checks on all my Windows machines:
  • C: Drive Check
  • CPU/MEM checks
The simplest way to achieve this would be to lump all my Windows Servers into a dedicated host group (say windows-servers) and then, rather than assigning the individual service checks to specific hosts, I would assign them to my fancy newq windows-servers host group I just made. From the Core Config Manager:
Now, whenever I add a host to my windows-servers hostgroup, it will inherit the "Drive C: Disk Usage" service definition I made.
rbuckle
Post by rbuckle »
So I have created a group for SNMP checks for a wireless radio... I have tried assigning services/service templates to the group but when i add a host to the group it does nothing but group the hosts together.
I seem to still have to manually create each service again and associate it with the new host.
Running:
OS: CentOS 7
Nagios XI
Enterprise License
rbuckle
Post by rbuckle »
OK, I found your guys video on inheritance and hostgroups... I think that i have it working now :)
Thank you
You may close the ticket
Running:
OS: CentOS 7
Nagios XI
Enterprise License
