Understand this is not a direct nagioscore related question.
how long the performance data will be rotated out of RRD db from pnp4nagios ?
Any pointer which file I should look at ?
How long is the data kept in RRD ?
Re: How long is the data kept in RRD ?
Those settings are stored in a file called rra.cfg. Take a look at it and you will see the settings for how long is stores the data.
It might be 4 years.
Thanks for your extra effort to answer this RRD question.
It is a 4 years retention period.
please lock this thread.
# 5840 entries with 360 minute step = 4 years
RRA:AVERAGE:0.5:360:5840
