Hi Team,
Can you please confirm is below setting will work on service dependecy. Where as NIX check /boot file system,NIX check /home file system,NIX check /root file system,NIX Check Load are different services.
On below setting i want to set dependency between NIX Processes Status and NIX check /boot file system,NIX check /home file system,NIX check /root file system,NIX Check Load
define servicedependency {
# config_name Test5-root_FS_Dependency
dependent_host_name Test5
dependent_service_description NIX check /boot file system,NIX check /home file system,NIX check /root file system,NIX Check Load
host_name Test5
service_description NIX Processes Status
inherits_parent 1
execution_failure_criteria w,u,c,
dependency_period 24x7
Nagios Xi service dependency
Regards,
Sk Abdul Goffar
Nagios Version:Nagios XI 5.4.8
OS:CentOS release 6.5
Sk Abdul Goffar
Re: Nagios Xi service dependency
That should work (all other things being equal), but you need to be mindful of how you modify flat-file configurations when using Nagios XI. See this documentation for more details:
Let us know if you run into troubles with configuring service dependencies.
