Event Handler for every event?
I'm curious if it is possible to have the event handler fire for every check, even if it isn't a state transition? I want to send events after every single check, even if the result of the check is OK and has been OK the previous time as well.
Reason: marking with green check mark
Re: Event Handler for every event?
You'll want to look into Obsessing: https://assets.nagios.com/downloads/nag ... hp_command
That looks like it might work. Thanks!
- Former Nagios Staff
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
Lock it up!dwhitfield wrote:It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
