Error when add or delete Hosts in CCM
oslec
Post by oslec »
When modify a Service in CCM, i have the error:
Error while inserting data into the database: Table 'nagiosql_tbl_ doesn´t exist.
Regards!
avandemore
Re: Error when add or delete Hosts in CCM
Post by avandemore »
XI > Admin > System Profile > Download Profile
Please include the zip file in your response. You can PM myself or other support personnel if you have privacy concerns.
Previous Nagios employee
ssax
Dreams In Code
Post by ssax »
What version of XI are you using? You can grab it from the bottom left hand side of the web interface.
Also, did this just start occurring or was there a change or something (upgrade, etc) that was done before you started experiencing it?
Please PM a copy of your profile, you can download it by going to Admin > System Config > System Profile and click the Download Profile button in the top right corner.
oslec
Post by oslec »
I find the error.- One Service with 935 Host...when add 1 or more hosts..
PHP Warning: Unknown: Input variables exceeded 1000. To increase the limit change max_input_vars in php.ini
I modify the max_input_vars to 3000 and CCM let me save correctly.
Regards!
