in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
ERROR WHILE INSTALLING NAGIOSXI ON UBUNTU 14.04
- Former Nagios Staff
Re: ERROR WHILE INSTALLING NAGIOSXI ON UBUNTU 14.04
XI is only supported on CentOS 6/7 and RHEL 6/7. You could install it in a VM if you must run ubuntu as a host OS.
Hi
Problem solved.
tq
Problem solved.
tq
Glad to hear. Is it okay to close the thread or did you have any more related questions?
