Showing multiple services on 1 chart
rbuckle
Post by rbuckle »
I have a group of snmp services monitored on a host, all the services report back the same type of information on different OID's (ie port1, port2, port3).
Is there a way to make these 4 services to appear on the same graph like download/upload does in the charts?
Thank you
Russell
Running:
Installed Version: 5.8.3
OS: CentOS 7
Nagios XI
Enterprise License
Re: Showing multiple services on 1 chart
Post by mcapra »
Using the "Graph Explorer" tool, you could build a Multistacked Performance Graph to achieve this:
