Disbale self signed certificate warning while using NagiosXI
Ayush Jain
Post by Ayush Jain »
Hi Team,
Can you please help me in disabling self signed certificate warning every time i am accessing Nagiosxi UI .
I have followed all the steps to enable ssl in Nagios server and its working as well. but every time i need to ignore this warning.
Need your help to remove it permanently while accessing nagios ui.
URL : https://<Nagios server>/nagiosxi/
version : 5.4.0
Let me know if u need more details.
Re: Disbale self signed certificate warning while using Nagi
You can either issue a proper certificate, or further attempt to disable checking it in your browser. (add an exception?)
I don't think there is much the Nagios team can do with that said as the issue is out of their hands.
Did @rkennedy's post clear things up or has the issue otherwise been resolved?
Ayush Jain
Ok sure , thanks!! will check and take a authorised certificate to heal this warning.
cdienger
Post by cdienger »
Let us know when you've had a chance to import a new cert or if you run into any problems. Thanks!
