I've been searching the net and can't find anything
Check diff of file
Check diff of file
Anyone of you fine nagios admins have a plugin for checking the diff of a file and reporting back what changed?
Basically I want to check /etc/passwd for changes and report back what was changed.
Reason: marking with green check mark
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Check diff of file
This plugin may work for you.
It doesn't report back what has changed in the file, only that is has changed.
Would that work for your needs?
https://exchange.nagios.org/directory/Plugins/Security/check_file_md5s/detailsWould that work for your needs?
I couldn't find one that did what I want, so wrote my own:
Feel free to lock this one up
#!/bin/bash
############## check_xx_file_diff.sh ##########################################
# Author : IT Convergence
# Licence : GPL - http://www.fsf.org/licenses/gpl.txt
# Contrib : James Clark
# ToDo : N/A
# Check for changes to file and report back what
# changed
# Changelog:
# 2017-03-01 - Version 1.0 - Plugin coding completed
# Added version information
# 2017-02-28 - Version 0.1 - Plugin started
# Set variables
VERSION="1.0"
VERBOSE=0
# Print usage
function usage()
echo "You asked for help, included a bad argument or not enough arguments"
echo ""
echo "./check_xx_file_diff.sh"
echo " -h --help"
echo " -d --directory = location of file to monitor(ex /tmp/)"
echo " -f --file = file to monitor(ex test)"
echo " -v --verbose = more information in output"
echo ""
exit 3
# Test for arguments
if [[ $# -eq 0 ]] ; then
usage
fi
# Parse arguments
while [[ $# -gt 0 ]]
do
key="$1"
case $key in
-d | --directory)
DIR="$2"
shift # past argument
-f | --file)
FILE="$2"
-h | --help)
usage
-V | --version)
echo "${0##*/} - Version: $VERSION - Written @ IT Convergence"
exit 3
-v | --verbose)
VERBOSE=1
usage # unknown option
esac
shift # past argument or value
done
# Start the real work
if [ "$VERBOSE" -eq 1 ] ; then echo "File to check = $DIR$FILE" ; fi
if [ ! -f $DIR$FILE ]; then
echo "UNKNOWN: $DIR$FILE was not found!"
exit 3
fi
if [ ! -f /usr/local/nagios/libexec/diff_$FILE ]; then
echo "OK: First check - Created test file!"
cp $DIR$FILE /usr/local/nagios/libexec/diff_$FILE
exit 0
fi
CHECK="$(diff $DIR$FILE /usr/local/nagios/libexec/diff_$FILE)"
if [ "$VERBOSE" -eq 1 ] ; then echo "Diff result = $CHECK" ; fi
if [ "$CHECK" = "" ] ; then
echo "OK: No Changes Detected"
exit 0
else
cp -f $DIR$FILE /usr/local/nagios/libexec/diff_$FILE
echo -e "WARNING: Changes Detected - Login to Nagios for full alert - Task is required!\n$CHECK"
exit 1
fi2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
- Former Nagios Staff
Thanks for contributing the script! I'll lock it up now.
