DISK WARNING - free space: /var 0 GB (49% inode=96%):
vyasdevaguddi
Post by vyasdevaguddi »
i have tuning the parameters in the system file .cfg and shouls i am seeing the alert
please help in the fixing the error
Re: DISK WARNING - free space: /var 0 GB (49% inode=96%):
You need to fix the service and modify your configuration to be different, or work through the problem with the plugin.
vyasdevaguddi
Which service you need to fix and configuration has been turned and how to verify the plugin
Post by mcapra »
Can you share the service definitions you are using? Also any relevant command configuration being used in the service.
vyasdevaguddi
This are the variables which we are using in the environment and its working for all servers and its have issue only with this server
use local-service ; Name of service template to use
host_name hostname
service_description Var Partition
check_command check_nrpe!check_disk '-a -c5% -u GB /var' -n
#notification_interval 10
#contact_groups Aix admins
host_name hostname
service_description var Partition
check_command check_nrpe!check_disk '-a -w15% -u GB /var' -n
#contact_groups Aix Warnings
command[check_hda1]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/hda1
command[check_disk]=/usr/local/nagios/libexec/check_disk -w 10% -c 5% -p /,/var/,/usr,/opt,/home,/tmp'
Post by mcapra »
Your check command doesn't exactly coincide with the NRPE command definition.
Here's what you're telling Nagios to do:
Where as your NRPE command definition isn't accepting any arguments:
So feeding it arguments in your Nagios check_command definition is pointless. If this check_command is not producing the desired behavior, the change will need to come in the form of altering the check_command or altering your remote machine's NRPE configurations.
vyasdevaguddi
what changes Need to be run to make and run the nrpe run successfully
please provide parameters for the nrpe to make it work
Post by mcapra »
If you can tell me the use-case you're trying to satisfy, I can certainly provide configuration sets. Based on the posts in this thread so far, it's unclear what exactly you're trying to do.
As an example from the NRPE end of things, I can create the following command definition to execute the check_disk plugin:
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
Then, from my Nagios Core machine, I can call that plugin remotely using check_nrpe like so (using -a to pass arguments into $ARG1$):
[root@core ~]# /usr/local/nagios/libexec/check_nrpe -H 192.168.67.97 -c check_disk -a '-w 10% -c 5% -p /var'
DISK OK - free space: / 3041 MB (17% inode=70%);| /=14836MB;16090;16984;0;17878
