I am having a problem with check_snmp.
When I issue snmpget I have no issues as below
[root@localhost ~]# snmpget -Le -r 3 -v 2c -c testing 10.10.10.20 sysUpTimeInstance
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (219524) 0:36:35.24
[root@localhost ~]#
But when I issue with check_snmp, it reverts to v1 as below
[root@localhost libexec]# ./check_snmp -H 10.10.10.20 -t 90 -v 2c -C testing -o sysUpTimeInstance
/usr/bin/snmpget -Le -t 90 -r 5 -m ALL -v 1 [context] [authpriv] 10.10.10.20:161 sysUpTimeInstance
CRITICAL - Plugin timed out while executing system call
Anything I define wrongly?
Please advice.
Thanks.
Check_snmp reverts to v1
Re: Check_snmp reverts to v1
Are you sure this is a Nagios Log Server question? I don't think check_snmp gets used anywhere in Nagios Log Server.
Your check_snmp command is using -v for the SNMP version, but this argument doesn't represent the SNMP version used:
You might instead try using the [-P snmp version] argument like so:
Usage:
check_snmp -H <ip_address> -o <OID> [-w warn_range] [-c crit_range]
[-C community] [-s string] [-r regex] [-R regexi] [-t timeout] [-e retries]
[-l label] [-u units] [-p port-number] [-d delimiter] [-D output-delimiter]
[-m miblist] [-P snmp version] [-L seclevel] [-U secname] [-a authproto]
[-A authpasswd] [-x privproto] [-X privpasswd]
[root@xi-stable ~]# snmpget -v 2c -c welcome2 192.168.67.105 sysUpTimeInstance
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (130723671) 15 days, 3:07:16.71
[root@xi-stable ~]# /usr/local/nagios/libexec/check_snmp -H 192.168.67.105 -t 90 -P 2c -C welcome2 -o sysUpTimeInstance
SNMP OK - Timeticks: (130733644) 15 days, 3:08:56.44 |
