Nagios Upgrade from 5.3.0 to 5.4.2 failing. Any help would be appreciated.
Here is the run log:
./upgrade
Failed to list unit files: Connection timed out
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.4.lin
Sourceguardian extension found for PHP version 5.4
Sourceguardian extension already in php.ini
** (pkttyagent:26855): WARNING **: Unable to register authentication agent: Timeout was reached
Error registering authentication agent: Timeout was reached (g-io-error-quark, 24)
Failed to restart httpd.service: Connection timed out
Here is the upgrade.log file contents.
Re: Nagios Upgrade from 5.3.0 to 5.4.2 failing
Can we get some more details on the environment? Specifically:
- What OS and version is this on?
- Is this a manual CLI upgrade or is it from the web interface?
- Can you PM me a system profile? From the web interface, Admin -> System Profile -> Download.
