Windows Update Check
Guys,
I posted this before but this is now a Nagios config issue
I got the check_ms_win_updates.ps1 working it was a bad line of code in the script. It now runs flawlessly from my Windows 10 Computer.
So now in Nagios I get this
TGKW001 WSUS Notifications for this service have been disabled UNKNOWN 03-04-2017 13:30:00 0d 0h 19m 44s 3/3 CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
In the nsclient log I see this
2017-03-04 13:25:38: error:c:\source\nscp\include\socket/connection.hpp:149: Failed to send data: The file handle supplied is not valid
2017-03-04 13:29:02: error:c:\source\nscp\include\socket/connection.hpp:149: Failed to send data: The file handle supplied is not valid
2017-03-04 13:31:00: error:c:\source\nscp\include\socket/connection.hpp:149: Failed to send data: The file handle supplied is not valid
In the NSCLIENT.INI
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
check_ms_win_updates=cmd /c echo scripts/powershell/check_ms_win_updates.ps1 $ARG1$; exit $LastExitCode | powershell.exe -command -
Thoughts
In the NSCLIENT.INI
Thoughts
Re: Windows Update Check
How long does it take for that check_ms_win_updates.ps1 script to run on your Windows machine if you run it manually? It almost looks like a timeout according to some other cases with that same error.
It runs in seconds the other day after I modified it.
Now again it is taken a very long time to execute. not sure why this is
Why would I not get a check nrpe timeout error if it is timing out?
How long can I put in the command line a timeout value -t 90 only 90 seconds how about 1 hour ?
Could it be that it is not running as administrator ????
Which NSClient++ version and Windows version are in play? Can you also share a copy of the script you're using currently? I'm going to lab this up and see if I get similar results.
I wouldn't suggest making the timeout value for check_nrpe much larger than the check interval at which it is executed. If you're checking every 60 seconds and the timeout is set to 90 seconds, you can have duplicate checks running at the same time which is not good.
My NSclient is version 4.4.19
Attached the script
My service
My command
My nsclient
My template
How can I make this check only once a week?
Tom
Attached the script
My service
host_name TGKW001
service_description WSUS
check_command check_ms_win_updates2
servicegroups Windows Updates
command_name check_ms_win_updates2
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 90 -c check_ms_win_updates -a '-wd 45 -cd 90 -M PSWindowsUpdate'
check_ms_win_updates=cmd /c echo scripts/powershell/check_ms_win_updates.ps1 $ARG1$; exit $LastExitCode | powershell.exe -command -Code: Select all
name windows-server ; The name of this host template
use generic-host ; Inherit default values from the generic-host template
check_period 24x7 ; By default, Windows servers are monitored round the clock
check_interval 5 ; Actively check the server every 5 minutes
retry_interval 1 ; Schedule host check retries at 1 minute intervals
max_check_attempts 10 ; Check each server 10 times (max)
check_command check-host-alive ; Default command to check if servers are "alive"
notification_period 24x7 ; Send notification out at any time - day or night
notification_interval 30 ; Resend notifications every 30 minutes
notification_options d,r ; Only send notifications for specific host states
contact_groups admins ; Notifications get sent to the admins by default
hostgroups windows-servers ; Host groups that Windows servers should be a member of
register 0 ; DONT REGISTER THIS - ITS JUST A TEMPLATE
Tom
check_ms_win_updates.txt- Powershell script
- (15.9 KiB) Downloaded 488 times
1 week is 10080 minutes, so you should be able to set your check_interval to that.
Haven't had a chance to lab this up yet, but i'll let you know if I find anything weird.
I tried the 10080 but the notification level is less then its check level
What should the notification level be set at
I posted in my other issue this
I answered in the other thread. Did you have additional questions specific to the Windows update check?
yes
How do we get that to work
The notification interval? The check interval? The plugin itself?
We can't offer much assistance with the update check plugin since we didn't write it. The information provided in the previous thread regarding the 1-week check interval should still be valid here:
1 week is 10080 minutes, so you should be able to set your Nagios object's check_interval to that.
