Error when trying to send test mail
vijilants
Post by vijilants »
System:
Nagios XI Version : 5.2.3
CentOS release 6.5 (Final)
Can someone please advise on the following:
Users have started complaining that no emails from the system seem to be getting genetrated.
When I tried to send a test email via the admin page, this is the message I am getting...
Mailer said: [03-06-2017 13:54:26] SMTP Error: Could not authenticate.
SMTP server error:
(method=smtp;host=XXXXX.XXXXXXX.net;port=3535;smtpauth=true;security=none), Referer: admin/testemail.php
An error occurred sending a test email!
Can someone please advise ?
gormank
Re: Error when trying to send test mail
Post by gormank »
Has it worked in the past? What changed?
Try sending mail to yourself from bash. The . on an empty line sends:
# sendmail -v [email protected]
test
What does the output say?
Post by dwhitfield »
Thanks @gormank!
Are you sending mail from the Nagios server, or do you have an SMTP relay? I suspect the auth settings are just not correct. If you aren't the mail admin, check with the mail admin to make sure you have the right port, address, and security settings.
Also, does your XI server have a valid DNS name?
vijilants
Post by vijilants »
dwhitfield wrote:Thanks @gormank!
Hi this has all been working for years and suddenly it stopped
Here is the Mail Settings:
Send mail from: "email address"
Mail method : SMTP
Host: SMTPOUT. XXXXX. XXXXX
Port:3535 ------I've also tried port 25
Username: XXXXX
Password: XXXXX
Is there any way of seeing if any email is backed up in the system as I would like to flush them out.
vijilants
Post by vijilants »
gormank wrote:Has it worked in the past? What changed?
test
Tried this....here is the output but I diodn't receive the test email.....
Mail Delivery Status Report will be mailed to <root>.
mailq will tell you if there is a queue.
What's the output of the following:
traceroute smtpserver
telnet smtpserver 3535
nmap 192.168.3.140  -p 3535
Have you spoken with the mail and network admins to make sure nothing has changed?
vijilants
Post by vijilants »
dwhitfield wrote:mailq will tell you if there is a queue.
Id' rather not post this info on a public forum thanks as it contains confidential IP information.
I am able to ping and telnet to the SMTP server.
Regarding your nmap command, where did you get 192.168.3.140 from ? Should it not be the smptserver address ? However...here is the result for nmap -p for the smtp server....
PORT STATE SERVICE
3535/tcp open unknown
I checked the debug log when I try to send an email and this is what I am getting....(I have put XXX in the address field to hide the server name)
[03-07-2017 04:45:54] SMTP Error: Could not authenticate.<p>SMTP server error: </p>
(method=smtp;host=smtpout.XXXX.XXXX;port=3535;smtpauth=true;security=none), Referer: admin/testemail.php
I've spoken with the mail admin (this is an external email service) and they claim nothing has changed.
The only other thing to look at is to see if the password has expired for the account used to authenticate to the SMTP server, can you check that?
Can the Email Admin of the SMTP server check in to that ans also look at the error log on the SMTP server?
vijilants
Post by vijilants »
tgriep wrote:The only other thing to look at is to see if the password has expired for the account used to authenticate to the SMTP server, can you check that?
I can log in to the mail account using a web front end client and using the credentials that I have in Nagios and also send email via the web front end client so the username / password is operational.
Unfortunately the service is with an external email provider so I can't get any response regarding logs.
Is there a process I could try restarting on the Nagios system ?
I really need to be 100% sure that it is not our system causing the issue.
You can try and restart the Nagios and the Apache daemons but I don't think that will fix it.
Run this as root to restart them.
service nagios stop
killall -9 nagios
service httpd restart
service nagios start
Then try and send a test email.
Another question to your email provider, did the port or the security settings get changed from None to TLS or SSL?
