Host Status Detail page - Alias Display Length
TBT
Post by TBT »
The Alias field has a character limit (of 64) when displayed on the Host Status Details page for any network element. Are we wrong to think this wasn't always the case, and also, is there a way to display the entire text field in these views?
Example, the text field is cut off: Court - Physical Internal Switch - Stack (ICRM / Corporate LAN - Second Floor, Room 2034)
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: Host Status Detail page - Alias Display Length
Try expanding the size by running:
echo 'alter table nagios_hosts modify alias mediumtext not null;' | mysql -uroot -pnagiosxi nagios
Note: If you changed your "default" db password or if you are using an offloaded db, modify the above command.
Let us know if this helped.
TBT
Post by TBT »
That works. For the sake of asking, what is the purpose of truncating that field, aesthetics?
There might not have been any specific reason beyond "I need a limit for this field and 64 seems long enough".
