ERROR: Subcomponent 'wkhtmlx' installation failed - exiting.
Nags007
Post by Nags007 »
Hi Team,
I am trying to install Nagios XI on RHEL 6.8 ( Santiago ). I am facing below error, when i run the ./fullinstall as root.
Latest update message for the ./fullinstall
ERROR: cannot verify assets.nagios.com’s certificate, issued by
Unable to locally verify the issuer’s authority.
Subcomponents installation failed - exiting
[nagiosxi]# grep proxy /etc/wgetrc
#https_proxy = http://proxy.yoyodyne.com:18023/
#http_proxy = http://proxy.yoyodyne.com:18023/
#ftp_proxy = http://proxy.yoyodyne.com:18023/
# If you do not want to use proxy at all, set this to off.
#use_proxy = on
[root@nagiosxi]# grep proxy /etc/yum.conf
[root@nagiosxi]#
Kindly help on this.
Thank you,
Nag.
Re: ERROR: Subcomponent 'wkhtmlx' installation failed - exit
We are working with you on this issue in another thread:
https://support.nagios.com/forum/viewto ... 89#p215089
I will be closing this one - please do not create multiple posts for the same issue.
