Configured around 14000 nodes in which around 200 nodes are still showing down.
1.Only using ping check for monitoring
2.Node is pingable with IP and hostname from the nagios server
3) Trace is also getting completed from nagios to node
Can you share me the troubleshooting steps what else i can check at my end
nope status showing down
ericssonvietnam
- node status.PNG (10.38 KiB) Viewed 1542 times
Re: nope status showing down
Can you post the full configurations for the AP_AP1 and AP_AP2 host objects?
ericssonvietnam
mcapra wrote:Can you post the full configurations for the AP_AP1 and AP_AP2 host objects?
below is the configuration for both the hosts
host_name AP_AP1
alias AP_AP1
address 10.105.1.229
host_name AP_AP1
service_description Service ping
check_command check_nrpe!check_ping
#Host 733
define host {
use linux-server
host_name AP_AP2
alias AP_AP2
address 10.105.1.230
host_name AP_AP2
The check_command for those 2 hosts show you are running the check_ping command on the remote hosts using the NRPE Agent and the check_nrpe command
and the command defined on the remote system os where the incorrect status is coming from.
Do you want to run the check_ping command on the remote hosts or from the Nagios server?
If you want to run the check_ping from the Nagios server, you would edit the service check and change the command from
to
If you still want to run the check_ping on the remote servers using the NRPE Agent, you would have to post the nrpe.cfg file from both of the failing servers.
check_command check_nrpe!check_pingDo you want to run the check_ping command on the remote hosts or from the Nagios server?
check_command check_nrpe!check_pingCode: Select all
check_command check_ping!3000.0,80%!5000.0,100%Be sure to check out our Knowledgebase for helpful articles and solutions!
ericssonvietnam
Re: node status showing down
Yes i am running the check_ping from the nagios server as suggested i have modifide the configuration for the host as shown below :tgriep wrote:The check_command for those 2 hosts show you are running the check_ping command on the remote hosts using the NRPE Agent and the check_nrpe commandand the command defined on the remote system os where the incorrect status is coming from.Code: Select all
If you want to run the check_ping from the Nagios server, you would edit the service check and change the command fromtoCode: Select all
check_command check_nrpe!check_pingIf you still want to run the check_ping on the remote servers using the NRPE Agent, you would have to post the nrpe.cfg file from both of the failing servers.Code: Select all
define host {
use linux-server
host_name AP_AP2
alias AP_AP2
host_name AP_AP2
But still will require few details from your side on the issue :
The node IP 10.105.1.230 is not pingable from the nagios server but if i am trying to ping my nagios server IPfrom the remotehost(10.105.1.230) it is reachable.
1. Can u tell me which ports does the Nagios core use for communication with the remote host for the above mentioned check with check_command check_ping!3000.0,80%!5000.0,100% also other required port for the communication to occur.
2. What testing i can perform to check the network reach ability,trace is getting completed from both the ends.
1. You would have to configure your device at IP address 10.105.1.230 to allow inbound ICMP for the check_ping command to function.
2. The check_ping would test the end to end from the Nagios server to the device.
